I think I got it working this is my first time using DSD and here's a picture of what I am seeing trying to listen to a DMR signal. I think I have a setting wrong. I am using the cable that plugs in to your discriminator tap and to the microphone jack. As you can see I'm getting ERR2 ERR 3 DCC=3 and DCC=7. Also in DSD+ Event log doesn't show any information accept the time stamp and the DSD+ info and digital info nothing about the events.
Looks like a repeater data burst that is sent out periodically.
BS Data- Base station
CACH- Common Announcement Channel
If there were voice in the signal you should get a talk group number and src/tgt (Radio ID) info in your channel activity , you'll also see VC2,3,4... In the display you posted. Every DMR superframe has 6 voice frames so the VC# just indicates each frame.
It also looks like it is a weak signal or you're not getting a good decode due to all of the ERR indications.
Verify you're not off on the frequency and if you're using a PRO-668 or PSR-800 try increasing the IF output on the scanner. Also check your line in level.
Maybe writing a simple batch file to lock the protocol (DMR decoding only) might help too.
Keep your scanner parked on that frequency for a while and see if you get any talk groups in your event log.
