dsdplus.sites file needed for SA
motorolavkg
Adelaide, South Australia
does anyone have the correct settings for the dsdplus.sites file, or a file itself for the commecrial networks ?
simoco, commwide, adelaide oval, etc ?
cant for the life of me get it working using the format in the file,the systems are as follows
and the site id`s and system id`s dont match whats on here
Simoco Australasia - DMR Tier 3
Orion Network - DMR Motorola Connect Plus (TRBO)
Motorola Rentals - DMR Motorola Capacity Plus Single Site (TRBO)
ComNet Nexedge - : NXDN NEXEDGE 9600
Adelaide Oval - DMR Tier 3
thewraith2008
You need to edit the following files:
  • .networks
  • .sites
  • .frequencies
DSDPlus will give information (not all) to help fill in these files.
If you have a starting frequency you can generally get information on related frequencies in a site from the ACMA register.
I think it's highly unlikely that anyone will just give you their files as they think they're gold.
And also it's a case of "Give a man a fish and you feed him for a day, teach a man to fish and you feed him for a lifetime"
motorolavkg
hence why i asked for the correct settings also,
and as stated the information posted on the RR page for the networks is wrong,
i have tried as you stated, editing the required files without success
kma371
What he is saying is start with no files and decode the system. Things should fill in automatically. Then, with correct files, you can update the DB as necessary.
thewraith2008
Settings can vary with each persons setup. ie.:
  • Hardware been used
  • DSDPlus version been used
  • Systems been monitored - which you supplied
Post what settings/record files you are using and we'll go from there.
