I wonder what is the lowest system requirements to run DSDPlus. I remembered that back in the days I was reading some statement that Intel Atom is able to run 4 insances of DSDPlus without any problem.
If you build DSDPlus dedicated machine, what hardware will you choose? Will you choose more powerful CPU, or maybe more RAM, or both... Please post your experience and include your hardware specs, type of system that you are listening and system load levels.
The lowest spec I've tried is an old Dell Vostro laptop, don't remember the exact model but it was with 4 gigs of RAM and Core 2 Duo T5300, running Windows 7 - no issues at all, decoding was fine, was monitoring NXDN48 trunked system. Don't remebmer what system load levels were. Currently I'm listening the same system on Lenovo Flex14, with 4 gigs of RAM, I3-4030U, Windows 8.1. During decoding CPU rarely goes to 20%, typically is around 15% and lower. First screenshot is when there is no activity on the system, and second one is when there is some active calls.
