DSR and DSD Plus - Just want to listen to one target
the064cobra
#1
I can't seem to find anything regarding a setting in DSD+ to only listen to one target (talk group). Is there such a thing or is this a different plugin that has to be used?
Toronto, Ontario
#2
Is DSR supposed to be DMR?
Pretty sure the current Fast Lane version will let you hear only the trunked or conventional talkgroups that you want to hear. Any group with its lockout flag set shouldn't be heard. No plugins involved.
#4
Edit your DSDPlus.groups file and replace "Normal" with "L/O" under the priority column of any groups you don't want to hear.
garys
Eastern MA
#5
If you only want to hear one specific talk group, set it to HOLD. Left click on the priority column until hold appears. The you will only hear that talk group. Alternately, you can go into dsd.groups and replace Normal with Hold.
garys
Eastern MA
#7
I found hold, but it took me a long time to figure out how to take a TG off of hold. I think I stumbled on that by accident and then read about it in the notes. :roll:
Forgot about HOLD! That is a good answer.
