DTMF to activate QC2
Wtrout
is there a way to make it to where if someone were to TX some DTMF tones, could it make it to where a radio put out QC2? is this possible, and if so, what do I need to do it?
Easy (?) way to do it is have a radio that will trigger an out put based on the DTMF, that trigger would set off the input to another radio that would send the QCII.
Why tho?
Wtrout
Why tho?
my why is that I want to build a repeater type deal that has all sorts of stuff, and I thought that would be cool.
OK, if it's for a repeater, then there are probably other ways to do it with a good repeater controller and some outboard add ons.
jeepsandradios
East of the Mississippi
Again why ? If its a repeater just use the radio to send the QCII command. I'd have to ask what the application is also as I'm sure if its ham or gmrs many folks wouldn't be thrilled to hear QCII tones going out all day.
FireHam32
Many repeater controllers are capable of sending QCII tones in response to a DTMF command. A friend of mine set his ham repeater up to do this for long tone zero so that he would be alerted if anyone tried to use that for help when he wasn't actively listening. Take a look in the manual for your controller. You may be surprised what features are available.
ffexpCP
wizard of odd
Michigan
Disregard the following - I completely misread the question. I'll leave it here for prosperity.
It can be done with limitations. Look at a DTMF tone chart. You will be limited to one row or one column of digits. You will ignore the common DTMF tone for that group, only use the differing tones.
I used this for temporary setups with pagers and old radios that couldn't encode QCII but had a DTMF keypad. Just tell the user to hold the digits for a second or two.
IFRIED91
Arrive alive
NYC area
White Plains FD In NY. Dispatches using 2 DTMF tones…sound something like ***beep beep in dial tones*** Headquarters engine 134 tower ladder 7 car 211. The location of your alarm is______”
