DTRS Location-Based Points/Radii Complete!
greenthumb
Colorado DB Administrator
For those of you using GPS-based scanners (e.g. BCD996T) and the RR the web import feature, thanks to the hard work our site owner (blantonl) for rolling out a tool to make this work easy on the admins., I have completed entering the lat/long coordinates and radius for each site and set of talk groups in the database for DTRS.
I am pretty sure that the entire trunking database for Colorado now has location based data for all sites and talk group sets, so if you encounter a set that does not have location data, please submit information for that system to let us know and it will be taken care of.
The conventional database will be worked on in the coming weeks. Enjoy!
Ryfly
I'm sort of lost on this.. What exactly is this going to do for our GPS scanner?
Thayne
Short answer: The Uniden 996 can use that info to change things in the way the scanner operates in case you are driving around.
jfab
Broomfield/Aurora, CO
This may sound like a stupid question, but why doesn't the 396t have this feature?
Thayne
Got me; maybe the shadow knows--My dad used to say you can't get 10lbs of "something" in a 5lb bag. :twisted:
GrayJeep
N. Colo.
A better answer
Ryfly said:
Why do you need the lat/lon for your scanner?
Sorry, i'm a real newb at this lol
So that as you travel the radio will start listening to the stronger control channels and stop trying to get the ones that are getting marginal. Better scanning performance would be the result.
If I understand it correctly the scanner requires an external GPS be connected to it. The scanner itself is not a GPS so it doesn't know where it is unless something else tells it.
