ClemsonSCJ
- Joined
- May 29, 2018
- Messages
- 227
Hey guys, I’ve searched the webs over and can’t find a NMO mount dual band antenna that’s 5/8 wave on 2m. Anybody got any suggestions?
Sorry, I was referring to 2m/70cm dual band. I was just hoping to get a little more range out of my setup. I had put a Larsen NMO 2/70 that I was just playing on with a UV-5R until I could get a good mobile radio installed. Got a ICOM 2730A installed last week and it will easily reach out to repeaters that are 25-30 miles away. But on simplex I hooked up the UV-5R to a magnet mount dual band antenna on top of my gun safe and set up an IP camera to it to see when it was picking up and I got the exact same distance with the 50w mobile radio as I did with the 5w baofeng before it starts cutting out, which was about 3 miles, best case. I assumed that if I’m hitting repeaters at 30ish miles then my handheld should pick up at least half that distance inside my house. Or at the very least double or triple the handheld’s transmit distance.When you say dual band which other band besides 2 m?
A 5/8 wave 2 m antenna with a series coil will function as a 1/4 wave on 6 m. If you are looking for a straight whip 5/8 wave 2 m antenna that also works on 70 cm then that's physically impossible. The closest thing would be something like a Comet SBB-7 NMO.
That antenna appears to be 1/2 wave on 2m and 5/8 over 5/8 on 70cm. Same thing as the Larsen NMO2/70.![]()
Dual Band 2 Meter/440 Mobile Antenna
Specs Gain: 2.4 dBd VHF-5.5 dBd UHF Pattern: Omni-directional Wavelength: 1/2-5/8-5/8 Elements: 2 Tuned: 144-148 & 430-450 MHz Band: VHF/UHF Rated Watts: 150 Cable: RG58U Cable Length: 17 Feet Mount Type: NMO Height: 38" Magnet Size: 3 5/8" Features Tuned to 2 Meter and 440 Ham...dpdproductions.com
So the weird thing about that is DX Engineering has the Larsen NMO2/70 as a “1/2 + 3/8” wave or 1/2 wave over 3/8 wave. Do you have something you’re referencing to get that spec?That antenna appears to be 1/2 wave on 2m and 5/8 over 5/8 on 70cm. Same thing as the Larsen NMO2/70.
My mistake, a Larsen antenna book I have from 2005 lists the NMO2/70 as a centre-loaded 1/2 wave on VHF and collinear on UHF.So the weird thing about that is DX Engineering has the Larsen NMO2/70 as a “1/2 + 3/8” wave or 1/2 wave over 3/8 wave. Do you have something you’re referencing to get that spec?
Get your specs from the manufacturer not dealers. Even then you need to be suspicious of published specs sometimes.So the weird thing about that is DX Engineering has the Larsen NMO2/70 as a “1/2 + 3/8” wave or 1/2 wave over 3/8 wave. Do you have something you’re referencing to get that spec?
It’s listed as “1/2” on 2 meter and “1/2 + 3/8” on 70cm. Not 2m.Get your specs from the manufacturer not dealers. Even then you need to be suspicious of published specs sometimes.
I have never see a NMO2/70 described as a “1/2 + 3/8” on 2 meters.
That's obviously wrong, because the ratio between 2m and 70cm is very different than the ratio between (1/2) and (1/2 + 3/8).It’s listed as “1/2” on 2 meter and “1/2 + 3/8” on 70cm. Not 2m.
Yeah everything else I’m looking up has “collinear” listed under the UHF frequencies which I take to mean 2 x 5/8.That's obviously wrong, because the ratio between 2m and 70cm is very different than the ratio between (1/2) and (1/2 + 3/8).
That is common standard practice. There are plenty of options to split UHF and VHF to separate antennas.So assuming I wanted to run 5/8 on both VHF and UHF, has anyone had any success utilizing a duplexer like the comet duplexer to use a single dual band radio on 2 separate antennas?
You can do that but it's probably a waste of money.So assuming I wanted to run 5/8 on both VHF and UHF, has anyone had any success utilizing a duplexer like the comet duplexer to use a single dual band radio on 2 separate antennas?
I’ll admit my knowledge on this, while progressing, is super fresh and limited. However from the reading I’ve done and applying it to my environment, I can’t imagine why 70cm performs exponentially better than 2m, yet it does. I’m going to do some more testing to make sure I’m getting accurate results, but I’m getting 2-3x, possibly even more distances out of 70cm than 2m. This is in an area with far more land/woods than houses and rolling hills, not much else, and my SWR is also much better on 2m than 70cm. The only factor that I can think of is that the antenna I have now is radiating more towards the horizon on 70cm and on 2m its strongest radiation is into the open air where no receiving antennas are located. Again, super limited understanding on this stuff so feel free to tell me if I’m sounding like an idiot and reaching. I won’t get my feelings hurt.You can do that but it's probably a waste of money.
On a vehicle you are not going to see a noticeable performance increase between a NMO-2/70 and separate 2 m 5/8 wave and 70 cm collinear antennas.
I can confirm this I have several vehicles equipped for ham radio (and I like collecting things), so I have more than one mobile antenna. As below:On a vehicle you are not going to see a noticeable performance increase between a NMO-2/70 and separate 2 m 5/8 wave and 70 cm collinear antennas.
