Dual Band Ham Repeater Antenna
brushfire21
NorCal - Napa Valley
#1
I am looking for a solid dual band repeater antenna, for this install fiberglass would be fine, icing can occur but not often, winds to 40-50mph have been known to occur as well as lightning (rare and no strikes at this site so far). Have a location that I would like a 6dbd antenna on UHF, VHF doesn't matter for gain and it's on a site that I need to keep lo-profile.
My favorite antennas are dipoles but I don't have the room to stack them in the case.
San Diego, CA
#2
Are you planning on running two repeaters through one antenna? For instance, a two meter repeater and a 440 repeater through the same antenna?
N4GIX
Hammond, IN
#5
It would be an interesting set of combiners to allow both VHF and UHF simultaneously, not to mention expensive.
In the 'patch
#6
Not really. A simple VHF/UHF diplexer will work just fine. Done this many times to have a UHF link radio and VHF repeater to use the same antenna(usually a Sinlcair 120-c2 or c4)
#7
Years ago I set up a guy in town with a low power UHF repeater on a Comet GP-9 commercial version and he used the VHF side of the antenna with his shore station marine radio through a diplexer. It seemed to work fine. I would never put a Comet antenna on a mountain top where it would get extreme weather or winds but in town they hold up fine.
prcguy
San Diego, CA
#8
My club tried this. We attempted to run a 2 meter Fusion repeater and a 440 Fusion repeater, both with their own set of cans, through a Diamond X-50 Dual band antenna with a simple diplexer downstream of the cans. It didn't work, at least not well.
The loss of gain in the dual band antenna and the loss through the diplexer rendered it impossible for those using only a handheld radio to get into the 2 meter repeated with any clarity. Those of us who could hit it with 50 watts or better didn't have any issues. We have since made the decision to dump the diplexer and put up a separate antenna for two meters. We had that configuration once before and no one had any issues with it.
In the 'patch
#9
The loss of gain in the dual band antenna and the loss through the diplexer rendered it impossible for those using only a handheld radio to get into the 2 meter repeated with any clarity...
Hmmmm. Done it with various configurations, some in a portable setup as well running 2 repeaters, and having a link as well. These were however either V/UHF MSR2000 paired, GM300/MAXTRAC mobiles, or some other commercial repeater. Usual stuff done, double shielded jumpers, RESLOC duplexers, hardline to antennas, and high quality antennas. Never had issues. Our radio quality was significantly better in selectivity and squelch operation than the Yaesu fusion repeaters.
Very few repeaters where I live run more than 20-30w before the duplexer. A good diplexer should have little loss, less than .5-1dB, we use little else than 7/8" hardline for our feedline. We will however throw in a preselector and a low gain preamp. Usually a touch more gain than system loss.
At one time Sinclair made a diplexer that combined 136-174MHz and 400-470MHz. To one port. N connectors all around. One of the clubs I belong to has 4, with three actively deployed at repeater sites.
My preference is to have separate antennas for V/UHF repeaters at the same site. Sometimes this is just not an option. Quite often, in Alberta, we will use the 210-C2/C4, used for the 2m repeater, and diplex a UHF link radio to the antenna hardline. Works remarkably well.
brushfire21
#10
This would be a single repeater with link radio as mentioned before in several posts. I will look into the Sinclair antenna but suspect it may be to tall and require more space then I have. Love having issue like this a figuring out a solution!
I appreciate everyone's input. Side note, to the user trying to use the x50 that was diplexed, I have heard other reports of others trying to use this same antenna with poor results in duplexed situation, something todo with it coupling into the feedline.
In the 'patch
#11
A Sinclair 210-c2 is a shade over 8' long. that makes it slightly longer than a 2 piece fibreglass vertical from any of the hammy fibreglass verticals.
Lots of options. the advantage of the Sinclair antenna is that it is not some crappy hammy toy vertical. It will likely be the last antenna you buy for the repeater.
Not sure what one expects, but when you buy cheap parts, you get cheap results. yea a $500 repeater looks attractive because it is cheap, but it is a $500 repeater with a couple of hammy toy mobiles in a box. Even a repeater made out of GM300 or MAXTRAC radios is going to be a better performer than a Fusion machine. Diamond fibreglass antennas are not something I would use for repeater service either. like a last resort. and even then, I would be more comfortable using(for a ham repeater only) a BSA kit with a 1/4 wave over a fibre-crap hammy antenna.
can not take short cuts with repeaters. Cheap repeater, cheap duplexer, cheap feedline, cheap antenna equals a crappy repeater.
the far east
#12
Amateur radio companies have been doing it for years, at least a dozen or so! It is called crossband repeat and is not very expensive at all I do not know why you would think that?
So Cali
#13
Link 'repeaters' are usually on a separate small yagi antenna horizontally polarized.
"Cheap repeater, cheap duplexer, cheap feedline, cheap antenna equals a crappy repeater." Exactly, no one wants to talk on a crappy repeater.
In the 'patch
#14
Not always. If it is a point to point link maybe, Repeaters that are linked in a 'hub and spoke' configuration that use a UHF repeater as a hub, and all the link antennas are vertically polarized.
Those Fusion repeaters are not much of a deal when you end up at a high noise site...
#15
no ham grade dual band antenna is designed for repeater service and will give you nothing but trouble
and they have ZERO lightning protection
the ONLY ham grade antennas I've ever used in repeater service are the g6-440 and the G6- 144
both are built like tanks and will survive hurricane force winds and heavy ice
stacked dipole antennas are the best way to go for repeaters
Rred
#16
Look into Polyphaser for lightning protection. No antenna will come with that built in, and for a repeater it should be considered essential.
Companies like Antenna Experts ( Fiber Glass Collinear Antenna, AC9-150, 136 - 174 MHz., 9 dBi. Gain - Antenna Experts ) make military grade "rods" that look like the much cheaper ham collinear antennas, but these will withstand 125mph winds, that's something like a Cat3 hurricane.
Even with lightning protection, if you are located someplace high, you can expect the antenna may need to be replaced from time to time.
#17
I run full duplex vhf 150 watts and a control link 70cm Uhf on X510HDM with no problems using Sinclair duplexes 6 pak and a Comet Dual band Diplexer.
N6ZLW
where they make the cheese
#18
just piling on
we run VHF and UHF machines on the same dual band fiber glass stick at 150ft fed with 7/8" line
both machines cover just as planned
each has it own set of BpBr cans feeding a diplexer and a polyphaser
175 DME, HEC 358° Radial
#19
Duplex operation with multiple transmitters and/or multiple bands can work, but it leaves you open to intractible desense problems that can be impossible to cure. The issue is low level mix products that are normally undetectable can manifest themselves on receiver frequencies that can't be filtered out.
Run a set of intermod calculations with a single transmitter frequency. Then do it again with the second transmitter. Add other on-site transmitters, and run it out to 5th and 7th order mixes. At some point, you realize that everything mixes with everything else, and mix products mix with other mix products, and it becomes amazing that anything works at all.
You might get products at -95 dBm that are too weak to radiate, but since they "live" in the antenna and feedline used by the effected receiver, you can't filter them out, if they fall on the receiver frequency.
In my opinion, this is why some people insist it works fine, and others insist it doesn't. You pay your money, you take your chances. Try it. If it doesn't work, just run separate antennas. Don't waste too much time trying to make it work. Especially if you don't have a clear and precise understanding of exactly what the problem is.
