Duplexer, Channel Spacing and Repeater Transmit Power Relationship
gdelacruz
Hello,
I'd like to ask the relationship of the mentioned devices with the following VHF scenario:
1. Tx and Rx spacing at 2.5MHz
2. Repeater 35W (max 50W)
3. Duplexer 50W
Questions:
1. The system is running with duplexer, is it safe to set my Tx power to 50W (max)?
2. Will my Tx saturate my Rx due to narrow frequency spacing?
3. Increasing power to 50W, can it kill my repeater?
Thanks and appreaciate any comment.
west-pac
This is the wrong forum to ask those questions. This forum is for scanners/receivers. There are other forums better suited for transmitters and repeaters.
Project25_MASTR
Millennial Graying OBT Guy
Texas
So...this will really depend on the type of duplexer being used.
The flat pack mobile duplexers need roughly 5 MHz of minimum separation. Various other designs require less. One of the things to consider, the actual isolation capabilities of the duplexer. A 50W rating means that the duplexer is designed to handle 50W of input power. It does not mean the duplexer can adequately isolate 50W of power without desensing the receiver.
N5XPM
Texas
While we need lots more detail, one key concept is that more power is not usually the answer. A higher antenna installation and lower loss coax usually helps improve performance more than increasing repeater transmit power. Project25_MASTR is on the correct path about repeater receiver performance. Reducing the repeater transmit power may actually improve the repeater performance more than increasing power.
prcguy
If the duplexer is rated at 50 watts its certainly a mobile flat pack notch only. 5MHz is about the limit on TX/RX spacing and if you go narrower the notches will cut into the passband and insertion loss will go through the roof plus isolation will suffer.
Depending on the radios used 50w or even 35w can be on the hairy edge of working at 5MHz split with some cheap radios not being able to duplex at all. With a marginal duplexer you have to rely some on the band pass filters in the radio receivers and low noise on the transmitters to avoid desense. At 2.5Mhz its not going to happen with a mobile flat pack and you would need something like a large 4 cavity pass/notch duplexer which can go down to a 1MHz split for some models.
