AR-DV1 DV1 firmware
Tom07
Northern Ireland
There hasn't been a DV1 firmware update now for quite a while. I wonder if that's the end of any new firmware? What do the members here think and what's your opinion? Maybe that's it and no more?
marlbrook
Devon, UK
There are some indications that instead of updating each DV1 and DV10 firmwares AOR attempted to integrate the firmware for the two receivers over the last year, resulting in problems for both radios.
I have little doubt this was brought about by the 'very expensive paid for' update relating to Tetra, the coding of which is stiil causing 'issues' according to various posts on other Forums. For some reason many seem to wrongly believe this will enable them to decrypt Tetra.
It has been some time since there was a stable firmware release for the DV1, which was the one prior to the paid for upgrade, and it appears there has never been one without problems for the DV10. Attempting to combine the firmwares serving only to create DV1 'issues' too.
Having released several 'flawed' firmware updates, one after the other, has made me lose all faith in AOR, especially their firmware 'quality control' and 'testing'.
palmerjrusa
Frederick
My DV1 will sometimes freeze up when it's scanning a memory bank with the squelch staying open.
Pushing the scan button to try and restart the scan doesn't work as does turning the squelch level back to zero.
Curiously, turning the squelch level all the way to its maximum value will sometimes unfreeze it and scanning restarts.
Infuriating.
marvintpa
England UK.
Infuriating.
I have noticed the same thing. Tried different firmware but still getting random lockups (sticking) on channels when scanning memories.
Easiest way to sort this is to just turn it off and on again.
I am starting to suspect power supply issues.
I have several radios running off of a 30amp PSU and noticed these lockups seemed to coincide after I had been using my HF receiver connected on the same psu.
So, stopped using that for a while but am still random getting lockups.
After sometime I have started to notice that these lockups seem to coincide if the internal fan on the PSU has kicked in.
Powering only the DV1 and a few ancillaries the fan never kicks in.
So I am suspecting my PSU may need looking at, ive had 20 years now and maybe the smoothing capacitors are drying out.
All the same, I am also suspecting that the DV1 is rather sensitive to spikes on its power input. Maybe smoothing capacitors have dried out in that as well? It is on 24/7.
Just some thoughts and observations that may be of help.
palmerjrusa
Frederick
Thanks for those observations.
I also was wondering if the freezing issue was contingent on the stored frequencies/modes, whether mixing different modes in one memory bank was causing it.
I need to try some experiments with the above in mind.
I remember this also happened with an old AOR AR8200 handheld I used to own. It too would freeze up when scanning a memory bank and you had to power down/up again to unfreeze the radio.
Tom07
Northern Ireland
So would sorting out a stable firmware version is possibly the best option rather than new add-ons. On new things im not sure what they could actually add?
MStep
New York City
On the advice of several other AOR DV-1 enthusiasts, I am still running version 1907B. It seems some of the issues started with 2101C, which attempted to add those Tetra GSSI "PRO" functions/features to the radio, as marlbrook pointed out above. Still a great radio, but now somewhat directionless in terms of further development. For that quick-fix of radio monitoring, the DV-1 is still my "go-to" receiver.
Zentral Europa
For me, the firmware 2108B (T) runs quite stable. So far, I could not determine any hangs (freezing). The memory banks are also sorted (no analog and digital frequencies mixed). The power supply is ensured by a 6/8 Ampere power supply unit, which partly supplies my ICOM IC-R 8500 at the same time.
Currently, I compare the DV-1 with the Airspy Mini, mainly for Tetra reception. Results will follow in a separate thread.
Tom07
Northern Ireland
Looks like there isn't going to be any firmware updates for DV1 this year. There hasn't been one for a very long time apart from the fixed GSSI flaw. Maybe that's the finished product as in terms of firmware for DV1. Maybe they're saving all the new stuff for the DV2
autodiag
Czech Republic
Vypadá to, že v letošním roce nebudou žádné aktualizace firmwaru pro DV1. Dlouho neexistoval žádný, kromě opravené chyby GSSI. Možná je to hotový produkt, pokud jde o firmware pro DV1. Možná ukládají všechny nové věci pro DV2
[/CITACE]
actually 2205A
