DVB-T+DAB+FM Issue
Texas
So I'm having issues with getting my tuners to work. When I run rtl_test -t, I get this:
Code:
Found 1 device(s):
  0:  ezcap USB 2.0 DVB-T/DAB/FM dongle
Using device 0: ezcap USB 2.0 DVB-T/DAB/FM dongle
Found Rafael Micro R820T tuner
Supported gain values (29): 0.0 0.9 1.4 2.7 3.7 7.7 8.7 12.5 14.4 15.7 16.6 19.7 20.7 22.9 25.4 28.0 29.7 32.8 33.8 36.4 37.2 38.6 40.2 42.1 43.4 43.9 44.5 48.0 49.6
No E4000 tuner found, aborting.
However whenever I run rtl_test, I always have loss:
Code:
colin@X101CH:~$ rtl_test
Found 1 device(s):
Info: This tool will continuously read from the device, and report if
samples get lost. If you observe no further output, everything is fine.
Reading samples in async mode...
lost at least 96 bytes
Any suggestions on what's going wrong? I'm still new to USB devices under Linux.
