BlackSheepDue
I have been struggling with this issue for awhile and can't seem to make any progress. When the E5 came out I upgraded both my 8500 and 7500 to E5 dash mounts. At the time I had them in a havis console as separate radios. I eventually swapped out the havis console and went back to my OEM console which meant less space. I figured the dual radio option the E5 offered would be perfect for me but ever since I went this route the radios will randomly restart every 15-30 minutes. Occasionally when they restart the screen displays "RC in progress" but not every time. Usually before they restart they become sluggish. What I mean is I can hit the swap button and it takes a few seconds or it just never swaps or I hit scan and it beeps but doesn't actually turn scan off etc...
I started with the minimum firmware that supported dual radio, R21 or R22 I believe. When my issues began I tried going up to R23 and ran that for awhile but the issues persisted so last week I went up to R24 but still I'm having the same issues. I checked and I am getting proper voltage everywhere. The truck is a 2019 F150 and it does have auto stop/start but I always turn that off. I use a charge guard which is powered directly off the battery and separate fuse panel which also powers a BCD536HP and Feniex light controller. Neither of these ever restart, loose power, or have any sort of issues. I have had apx's in this truck for 2-3 years and never had any issues until I went to a dual radio setup. The radios transmit fine and otherwise work well in between restarts.
I've tried everything I can think of so I welcome any and all ideas. I tried to include everything I thought was relevant in the paragraphs above but let me know if there's anything else you want/need to know.
