Earphones compatible with G4
bravestphotog19
Any suggestions on earphones that work well with G4 and have decent audio? I have only found one so far that actually will pair up with pager and the audio level is horrible even with volume set on 100.
K9KLC
Southwest, IL
I've tried several JBL ones and they all paired. I will say the volume needs to be up pretty well to hear them if there's any noise around. I'm getting a little hard of hearing however, so some of that may be me.
pto
Grundy Co. IL.
l like the JLab Go Air Sport or the + versions. As mentioned, volume needs to be up, but not full. I have several jlab versions, they work well.. Pairing, the first time is kinda tedious, after You get the hang of it, it’s fine. And the G 4 automatically pairs after the initial pairing. I buy them on Amazon.
inlandpatch
Southern California
I use the Shokz OpenRun and works well and connects great. I have also used my Apple Air pods pro (Gen 1) and works when I finally get it paired. But as for the volume, yes, it is terrible and seems to be universal regardless of what headphones you use. Wished they fixed that, so it is louder when you are in loud environments. If you search headphones in the Unication form you can see other suggestions on headphones or Bluetooth speakers.
