East Texas Fires
Boulder
Wood County, TX
I noted several air frequencies that were in use from the Bear Creek fire and other fires from around the area:
121.1750 was used for helicopters working the fire
124.3750 was for fixed wing
Also 166.9375 for air to ground communications once the feds got there
