Eave Mount Question
jonwienke
More Info Coming Soon!
VA
The shorter the distance, the weaker the mount. You'd be best off running your pole down to ground level, securing the bottom of the pole in concrete, running the pole through the eave mount, and using a longer pole (or 2 sections) than relying on the eave mount by itself.
Extending the pole down to the ground will also facilitate properly grounding the antenna.
