Ohbe1
After switching over to Windows 10, the audio out was garbled and I was unable to correct it. Also, Echolink did not have a proper uninstaller and after trying to uninstall it, I lost functionally of Start and search on Windows 10. I ended up having the system reinstalled with windows 8.1 and then updated to 10. I tried a 2nd time and ended up with the same results. I was able to restore the computer prior to the 2nd attempt and got Start and Search back. Echolink has not been updated since 2003. I would advise avoiding an update to 10 if possible. There is a known problem with the InstallShield un-installer on Windows 8 and Windows 10. Please do not attempt to un-install this EchoLink package after you've installed it. An updated package that is compatible with Windows 8 and Windows 10 is in the works. I hope they will update the version too.
