greenthumb said:
Well, if the radio has 3 sites in it that have the exact same frequencies, LCN, and site number, it won't matter where the user is - the radio will affiliate with that site. As such the situation may occur where the user appears to be affiliated with a site in the north part of the state (based on what is shown on the radio's display) when he/she is in the south part of the state. Therefore, if they mix up the LCN, the sites are different and the problem is solved
Ok now I'm a little confused. I can understand the nearby or adjacent neighboring entities that are not supposed to be affiliated for reasoning (except in my example there is no nearby or adjacent entities
). But my understanding (and this could be wrong) of EDACS is that no matter what site/tower a person is on, the assignment of "dispatch/home" was based on talkgroup not tower/site. To further illustrate my understanding (or lack thereof) is that a radio could travel the entire state yet still be in contact with the same dispatcher no matter what site/tower they are using. And dispatch could release them to a different dispatch center. Also on my scanner which is obviously not the same as a radio, with TX/RX and built around a specific application, I can know which tower or site I'm listening to simply by displaying a short line of text associated with a frequency stating "Reno Met 09" and the next line with talkgroup. In this case Reno Met 09 is a tower in Reno Metro using frequency 09 in LCN. I "assume" a TX/RX radio has the same capabilities??? What you are saying (what I'm hearing) is that someone travelling across the state must somehow manually switch or indicate which site they are going to be using? It would seem to me that the average operator doesn't need to know or care which site/tower they are using. I would also think that requiring operator intervention would create a lot more problems than it would solve.
Are radios(TX/RX) that much smarter than a scanner? Can a radio be travelling across the state and automatically adjust for LCN changes of the same frequencies? From those who use radios that I sell scanners to they indicate that for the most part their interaction with the radio other than keying and adjusting the volume is that they can switch to "Red", "White", "Tac 1" etc etc etc.
Now regarding a scanner, This seemingly creates a nightmare of channel posibilities (you'need many, many banks of several LCN's and not scan banks that have similar freqs) because if I programmed a bank with those frequencies in my scanner, the scanner would become confused because there would be 3 (example above) entries of the same frequency followed by two different frequencies but I'd need to program all 3 series for my scanner to decipher the communications. And if the scanner picked up on one of the freqs out of a different series LCN the scanner would loose the control becuase on an EDACS system the freqs MUST be in LCN whereas (my understanding) on a Motorola system you could just program all the frequencies the wide area has, yes????
Please tell me this is (or I am) wrong. Because if I am understanding this correctly, why on gods green earth would anyone buy an EDACS system for use in a wide area network. Surely I am missing something here or the radios are that much significantly smarter than a scanner.
*Radio = a device capable of TX/RX and designed for a specific application
*Scanner = a device for listening in not designed for the application
