EDACS Networked Standard
scanner92
Is it possible to scan an EDACS system, but just one site? For example in the collier county system, I want to scan just the naples area. So I try to scan the first site. 001. When I input the frequencies in LCN order, it wont trunk. I hear voices, but I get that horn and beeping sound... Help me out... Please
loumaag
Silent Key - Aug 2014
Katy, TX
As an additional note, in answer to your question, "Is it possible to scan an EDACS system, but just one site?" That is the only way you can scan most EDACS systems. Since they must be in LCN order two different frequencies cannot be in the same LCN slot.
mciupa
Canadian DB Admin
Moderator
I'm here a lot
scanner92 , which channel number on your scanner are you starting at ?
Please program starting from the first channel space in the bank. e.g. (001,101,etc.)
Does this clear up your trunking problem ?
