I installed discriminator tap using 47k 1/4 watt resistor with a 10uF 16v Capacitor. Frequencies uploaded to scanners using ARC 500 and Inverted. I receive Provoice audio from dsd running in linux 10.4. I have Unitrunker version 22 setup running a Pro197 for signal and tapped Pro106 for voice. Signal is being published. Using default Unitrunker Baud Rate 115200, Data Bits 8, Stop Bits 1, Parity = None. Mode is FM, Provoice alone selected, EDACS96 alone selected, Only signal Radio has chase and publish selected. Signal running 98% Health. Voice running 0.Have run oxscope in linux to adjust levels to 50%. Have a good squared waveform also in Uniscope. Music audio from linux performs well on windows soundcard. Audio output set at lowest 44.100 16bit. External mike interface set for 20db extra. Provoice is for the most part garbled or encrypted I think, with intermittent clear parts that do not have a bunch of equal signs with R's in it. I am almost at my wits end. If this is system I am trying to monitor is Provoice enc maybe I would throw away my cash on buying an LPE radio. I will look for switches in dsd. I have already inverted in ARC 500.
