Edison
#2
Devils4121 said:
Can I listen to Edison on a radio with smartnet even though they are on smartzone
thanks
If it's a scanner you are referring to, i believe the answer is yes. If not, you should ask in the Motorola forum.
NJ USA (Republic of NJ)
#3
thanks
Provided you are authorized to have a radio programed to their system it should probably work as it is a single site system per the RR DB. It just needs to be programed to the one
site. You did not mention what model of radio so I am just assuming you have one that is capable and has the necessary features.
W2SJW
Senior Member
Moderator
Northwest NJ
#4
If you have an actual /\/\ radio that's provisioned in the codeplug as SmartNet only, you might have difficulty following that system.
The features only work in the 'backwards compatibility' mode (i.e. - if you have the H38 SmartZone feature, it is compatible with & includes all the SmartNet features as well).
