BCT15X: Edit Mode
Rescue37
Which buttons do you hold down while you power on to put the scanner into its edit mode. Use to know but forgot which ones.
rcool101
Eastern Ohio
Edit Mode?..... Sounds like your trying to do a factory reset...:roll:....That will wipe it clean....
Voyager
There is no EDIT MODE on the scanner. You can edit the contents at any time.
Only GRE/Whistler has an edit mode (called Program mode).
Rescue37
I can't remember but I thought when you connect it via cable you had to turn it on a certain way to program it.
