EF JOHNSON 5100 ES UHF QUESTION..?
KC0CCB
Whitewood, South Dakota
hello all,
i just received a 5100es UHF from a friend of mine and i brought it home and was going to try to read it in the CPS and it wont even read..
i am using a aftermarket cable that works well for the XTS-3000 i have but not this Johnson radio..
cmjonesinc
I was going off of your first post with 2.18.6. But either way, it's the same. Are you reading the radio first? If you're not reading the radio and just trying to make a codeplug from scratch you'll need to 'file' ---> 'new' and select your bandplan. Also will need to 'radio' ---> 'series' and select your model. Can't remember how well that works once you read the radio and it updates the feature set. I would suggest reading the radio first (AND SAVE THE ORIGINAL) just to save some future headache.
DeoVindice
P25 Underground
Gadsden Purchase
Ebay seller "bluemax49ers" sells excellent and reasonably priced programming cables. I have his FTDI USB-Serial cable for programming my EFJ's. Works flawlessly, not only on Windows but on MacOS with PCConfigure running in a VM.
While the 5100 shares mics, batteries, and some other accessories with XTSs, programming cables are not the same. I'll second the recommendation of a BlueMax cable. I have a USB/serial EFJ cable with the FTDI converter; it works perfectly on 64-bit Windows 10.
I strongly suggest you download and read the latest PCConfigure manual you can find. PCConfigure is somewhat complex and not as intuitive as, say, various Kenwood KPG versions.
I'm about to call it a night and am not in front of my computer, but if I'm remembering correctly talkgroups are created via a dropdown menu tab in the "System Lists" bar of the "Per System" tab.
cmjonesinc
'Not intuitive' is a good explanation. I've been programming them for a decade and still have to scratch my head for a minute every once in a while. Had to blow the dust off my old hard drive just to make those screenshots.
