EF Johnson 5100 Scan List
KG5HHS
D/FW
Hello All,
I have programmed my EF Johnson 5100. Is there any way to program the radio to scan its respective scan list when put in a particular zone? (IE. when I switch from zone 1 to zone 2, it will start scanning zone 2 instead of still scanning zone 1.) the only way I am able to scan zone 2 when switch from zone 1 to zone 2 is to turn off scan, go into the menu, select scan select, select list 2, then turn scan back on. then do the process again when I go back to zone 1.
AD0TY
Indiana
Each talkgroup you enter has a place to select the scan list you want to use. So you should be able to select list 2 in the programming in that zone. The only thing that sucks is that you have to do it for each talkgroup in the zone, you can't just do it for the whole zone.
wa8pyr
Staff member
Lead Database Admin
Ohio
Hello All,
Two ways (and a third that's sort of a workaround):
1 - The talkgroups or channels in the zone each have to specify the scan list. When you switch to that channel that's the scan list that's used. Of course, this doesn't help with talkgroups when the same one is used in multiple zones. You can at least put conventional channels in multiple times with different settings, but you can only enter talkgroups once.
2 - Switch scan lists manually.
3 - Use the radio-wide scan list. It's sort of a workaround, but will allow you to scan across systems and so forth; it's limited to what's in that list.
It you're only using conventional channels you could create a new conventional system for each zone, and re-enter the channels with a different scan list for that particular zone, but this is really wasteful of memory space.
KG5HHS
D/FW
I think I got it all figured out and programmed correctly. Thank you all for the help.
