EF Johnson 5100 VHF
wcu02mpa
Asheville,NC
I have recently acquired a 5100 VHF model-3 with FPP. I have the software but cannot get this thing to read. I using a serial cable (yes the com is set to com-1) but am wondering if a USB cable might be better. I can actually do quite a bit using the FPP, but cannot change a channel to digitial P25 like I can with my XTS5000 with FPP.
Can that be done via FPP or do I need to do it through the software?
Any advice on read/write for this radio? I am very proficient with most Kenwood/Motorola/Vertex programming but this one is giving me a fit.
Model number: 242-5113-620-BB
cmjonesinc
Are you using the right cable? I know moto cables look the same and fit but they're not the same.
marcotor
I ♥ÆS Ø
Sunny SoCal
EFJ's are pretty particular about what SW version works with what Firmware.
Whats your Firmware version?
wcu02mpa
Asheville,NC
Correct cable yes
I do have the correct cable, but am not sure about the software version or firmware version. So is there a chart or page somewhere that shows what goes with what?? Thanks again
FFPM571
Nashvillle
Also you may have to play with the baud rate when reading the radio and also make sure the software is booted fully before hooking up the radio to be read
jim202
New Orleans region
Most of the Johnson radios don't like to be programmed with a fast clock speed computer. I have run into this many times. So I keep a slower laptop computer around just to program the 5100 and 5300 radios.
You might also have an issue with the version of the software your using. The EFJ 5100 and 5300 radios have a multitude of different versions of the software. It sort of depends on where the radios were made (MN. or TX.) and what firmware is in them. When you first turn the radio on, you will notice that there will be 2 sets of numbers that very briefly display on the radio. You need to try and write those down and those numbers will define just which version of the software you need.
I don't have a chart to look them up on, but there use to be a web site for EFJ radios. One of the members on there would help people determine which version of the software they needed. Getting a copy of the required version software was the next problem.
