Elad FDM-S1 & FDM-S2
KC1UA
Scan New England Janitor/Maintenance
Marstons Mills, Cape Cod, Massachusetts
Further details would be helpful. I have installed one of the latest revs of the Elad software in both Windows 8.1 64 bit and Windows 10 Tech Preview 64 bit without issue. I have the FDM-S2 SDR; great little device.
prc117f
Make sure your AV is disabled when installing. Otherwise it deletes key files during install.
Uninstall the bad client, rerun the full installer with AV disabled.
KC1UA
I hadn't thought of that when I did my installs, but that said they went fine while the AV software ran merrily in the background. Odd. But it's a valid issue in some cases and should definitely be part of the troubleshooting process.
NYG
Hi the Elad receivers are working doing an excellent job monitoring the hf aircraft bands comparing them atm to my JRC NRD-545DSP.
Regards Lino.
Excellent. I find my FDM-S2 to be a remarkable little radio.
Turbo68
East Devonport,Tasmania,Australia
Hi cannot wait till i test against my other hf receivers from aor,commradio,cross country wireless,drake,grundig,icom,palstar,sangean,ten tec,winradio but im very happy with the Elad receivers performance.
Regards Lino.
prc117f
Real good radio. I just heard there is supposed to be an FDM-Sx companion radio that is 16bit FPGA based and covers 50Mhz to 2ghz
Probably will cost 600-700 bucks. But it would be worth it if the FDM-S2 quality is there.
