RedPenguin
- Joined
- Feb 28, 2007
- Messages
- 1,082
I have a question about ferrites and even though I researched them on the Internet, I am not sure if they will help in the following situation or if I need something completely different.
I have a BR330T (plugged in with stock AC adapter in power strip) which while NOT receiving anything, records a constant noise no matter what computer or sound card it's hooked up to. It uses a Diamond RH77CA antenna.
I am wondering if I should just snap ferrites on the plug but how do I choose the type of ferrite?
So far, I've seen the following:
Snap-Together Ferrite Choke Core - RadioShack.com (Snap-Together)
Snap Choke Core - RadioShack.com (Snap Choke)
Would I even need a ferrite in this case?
I thought it was interference on my whole house AC lines but my BCT15 does not get it at all.
Here is a recording what the interference is I seem to be picking up, that I never seem to hear when I don't record and just listen to the scanner itself.
http://adam.250free.com/sound.wav
I'm kinda lost because I don't know if it's actually electrical, connection between scanner and PC (audio cable) or what. Is it just normal? If not, will ferrites even help in this case?
EDIT: I have tried the Radio Shack Ground Loop Isolator and even the Attenuating Cable, nothing seems to help this situation except I never tried ferrites, though I should, I know I have a snap on one I got from a PC item (I forget what it was) I was got rid of.
