Enbridge Gas Distribution frequencies update
Saint
Fort Erie Ontario Canada
Someone just updated the Enbridge Gas frequencies on the RadioReference.com page, I know that when I put in St. Catharines 452.550 I set it up as a EDACS SCT system on my bc250d scanner also the Fort Erie frequency 451.8125 I do the same in another bank. How do I set up the Fonthill site that has more than one frequency ,
452.9375
452.9125
451.3125
452.0375
454.6375
Do I put these in as a EDACS wide system or EDACS narrow system or do I set them up as a edacs sct system ???
Steve
DaveH
Ottawa, Ont.
You seem to be referring to the Fonthill site. It would be a regular wide EDACS system, not a set of SCATs. Use the usual LCN ordering rule. if you see only one channel per site, it is *probably* a SCAT, or the other channels haven't been found yet.
Mike O. mentioned that SCATs are scanned but not really tracked in the same way as a system. Judge accordingly.
The site numbers do not necessarily correspond to the System ID for each site, and there are duplicated sites with different versions of the same name, plus a few strange ones. Some sort of cleanup will be needed.
Dave
Saint
Fonthill site
Thanks Dave, I had a feeling Fonthill was to be setup as edacs wide system, I should have my 2 level data slicer tomorrow or the next day, I will see if I can listen to the system and figure it out. If I find any more information using some of the decoding programs I will submit the info to this site.
Steve
