Enclosing IP67 rated device in a metal case
ASAD
Bucks County, PA
Hello, could I get some advice on security camera installation? I bought IP67 rated security cameras to be installed outdoors. Now I want to protect my investment. Would it be safe to enclose them in a PELCO enclosure/housing to prevent possible vandalism or damage by intruders? In doing so, I am worried about cameras' heat dissipation. Temperature here normally goes above 100 degrees in summer and falls below 45 in winter. Will the camera stand the heat in a an unventilated case?
prcguy
The camera consumes power and makes heat. Putting it in a sealed box will allow heat to build up. An enclosure exposed to the sun will get hot. The end result sounds like hot hot hot.
At the very least I would consider a small fan and an intake opening to vent heat from the enclosure if that can be accomplished without letting any rain water in. It would also avoid condensation and fogging on lenses and any clear windows.
