Encryption Keyloading a Viking Series Radio???
emt0423
Clintonville, WI
#1
Has anybody keyloaded a Viking series radio??? Specifically a VP5000 or VP6000. Is there anything special that needs to be done to put it in keyloading mode and will my older key loading cable work??? My keyloader is a KVL 3000 plus.
Thanks for any help.
#2
The Viking radios should automatically go into keyloading mode once they detect that a keyloader is attached to the sideport. If that's not happening, then you likely have the wrong cable.
cowand
Nashville, TN Area
#3
I've key loaded several VP900s with a KVL3000. Our VP900s will sense the keyloader when the cable is attached, even if the cable is not attached to the keyloader. Good luck...
