Enterprise NXDN LCN order?
Russell Co. Ala.
#1
Can someone post Enterprise NXDN (WQPH310) systems LCN order. There not in the database and I must be to far away to get them with my scanner. I can hear them with the freqs. in conv. mode so I want to set up the trunk system . thank you
buddrousa
NW Tenn
#2
You may have to learn to do it yourself. If you can hear traffic you can find the LCN's It takes patience and hours sometime to get the information. If the system is not busy you may have to wait until the system gets busy to get the info. When you get your info please post to RR so others may find the data.
Russell Co. Ala.
#6
Well the two weeks of skip was nice put I lost Enterprise Sunday on there freqs. in conv. mode. Still wish someone from down there could post the LCN order
millam
#7
Enterprise LCN list
This is what I could determine from about a year ago, haven't listened to them lately. 154.37 is the
control channel transmitting all the time.
Mil
;Enterprise
NEXEDGE96, 148, 1, 1, 154.370, 0.0, 1
NEXEDGE96, 148, 1, 2, 156.195, 0.0, 2
NEXEDGE96, 148, 1, 3, 154.445, 0.0, 3
NEXEDGE96, 148, 1, 4, 155.700, 0.0, 4
NEXEDGE96, 148, 1, 5, 155.625, 0.0, 5
CANCEL all of the above, I remembered that Enterprise had left 148 and is on on 337. I just
looked at DSD on 154.37 and they are using L337-9 now. I'll listen and see if the LCN line up
is the same.
Mil
millam
#8
Enterprise LCN list
The LCN order is the same just on a different network. 154.37 is still CC.
;Enterprise
NEXEDGE96, 337, 337-9, 91, 154.3700, 0.0, 91
NEXEDGE96, 337, 337-9, 92, 156.1950, 0.0, 92
NEXEDGE96, 337, 337-9, 93, 154.4450, 0.0, 93
NEXEDGE96, 337, 337-9, 94, 155.0700, 0.0, 94
NEXEDGE96, 337, 337-9, 95, 155.6250, 0.0, 95
Russell Co. Ala.
#9
Thank you sir for the info. I will try those LCN cause I am getting Enterprise some what after the sun goes down. If there right I will post them in the database.
millam
#10
Here is what I have for network L337 if you need it.
;Andalusia / Opp / Covington County / Luverne / Enterprise ????
NEXEDGE96, 337, 337-1, 1, 154.7550, 0.0, 1
NEXEDGE96, 337, 337-1, 2, 154.1525, 0.0, 2
NEXEDGE96, 337, 337-1, 3, 155.0925, 0.0, 3
NEXEDGE96, 337, 337-1, 4, 155.9550, 0.0, 4
NEXEDGE96, 337, 337-1, 5, 153.6500, 0.0, 5
NEXEDGE96, 337, 337-1, 6, 158.9850, 0.0, 6
NEXEDGE96, 337, 337-1, 7, 151.5875, 0.0, 7
NEXEDGE96, 337, 337-1, 8, 159.1050, 0.0, 8
NEXEDGE96, 337, 337-2, 9, 151.7150, 0.0, 9
NEXEDGE96, 337, 337-2, 10, 153.2825, 0.0, 10
NEXEDGE96, 337, 337-2, 11, 152.8850, 0.0, 11
NEXEDGE96, 337, 337-2, 12, 153.1250, 0.0, 12
NEXEDGE96, 337, 337-2, 13, 151.5500, 0.0, 13
NEXEDGE96, 337, 337-2, 14, 151.7150, 0.0, 14
NEXEDGE96, 337, 337-2, 15, 153.2825, 0.0, 15
NEXEDGE96, 337, 337-2, 16, 160.0650, 0.0, 16
NEXEDGE96, 337, 337-2, 17, 158.3100, 0.0, 17
NEXEDGE96, 337, 337-3, 18, 152.9150, 0.0, 18
NEXEDGE96, 337, 337-3, 19, 153.6650, 0.0, 19
NEXEDGE96, 337, 337-3, 20, 153.1700, 0.0, 20
NEXEDGE96, 337, 337-3, 21, 153.2300, 0.0, 21
NEXEDGE96, 337, 337-3, 22, 153.5600, 0.0, 22
NEXEDGE96, 337, 337-3, 23, 152.9150, 0.0, 23
NEXEDGE96, 337, 337-3, 24, 153.6650, 0.0, 24
NEXEDGE96, 337, 337-3, 25, 159.9150, 0.0, 25
NEXEDGE96, 337, 337-3, 26, 160.1850, 0.0, 26
NEXEDGE96, 337, 337-3, 27, 159.6150, 0.0, 27
NEXEDGE96, 337, 337-4, 41, 151.8950, 0.0, 41
NEXEDGE96, 337, 337-4, 42, 153.5300, 0.0, 42
NEXEDGE96, 337, 337-4, 43, 154.4900, 0.0, 43
NEXEDGE96, 337, 337-4, 44, 151.6550, 0.0, 44
NEXEDGE96, 337, 337-5, 51, 152.9375, 0.0, 51
NEXEDGE96, 337, 337-5, 52, 153.3425, 0.0, 52
NEXEDGE96, 337, 337-5, 53, 151.5275, 0.0, 53
NEXEDGE96, 337, 337-5, 54, 151.6625, 0.0, 54
NEXEDGE96, 337, 337-6, 61, 153.3050, 0.0, 61
NEXEDGE96, 337, 337-6, 62, 153.5900, 0.0, 62
NEXEDGE96, 337, 337-6, 63, 152.9000, 0.0, 63
NEXEDGE96, 337, 337-6, 64, 154.4825, 0.0, 64
NEXEDGE96, 337, 337-7, 71, 152.9750, 0.0, 71
NEXEDGE96, 337, 337-8, 81, 151.7750, 0.0, 81
NEXEDGE96, 337, 337-8, 82, 153.0125, 0.0, 82
;Enterprise
NEXEDGE96, 337, 337-10, 101, 152.3000, 0.0, 101
NEXEDGE96, 337, 337-10, 102, 153.1850, 0.0, 102
NEXEDGE96, 337, 337-15, 151, 153.2600, 0.0, 151
NEXEDGE96, 337, 337-15, 152, 153.4850, 0.0, 152
NEXEDGE96, 337, 337-15, 153, 152.2850, 0.0, 153
NEXEDGE96, 337, 337-15, 154, 152.9600, 0.0, 154
blantonl
Founder and CEO
Staff member
Shavano Park, TX
#11
I went ahead and updated the database with the correct LCNs for Enterprise.
Can anyone advise if the Enterprise site is part of the wide-area S&P system or is it separate?
millam
#12
dsd shows that that L337-9 has neighbors 5 & 15. 15 freqs are assigned to s&p comm.
Someone with trunking knowledge will have to answer that. I don't know if Enterprise can
let S&P use their freqs on S&P's network system. I think that Andalusia's freqs are used by
S&P like that.
Mil
Russell Co. Ala.
#13
I can confirm the Enterprise LCN are right. Thank you Mil for the info. Would you happen to have any on Elba and New Brockton. I only get down that way around X-mas to see my kinfolks but the info would be nice to have.
millam
#14
Elba used to be on 153.8 and Coffee county was on 155.97. 155.97 has gone DMR
and I think maybe Elba and Coffee county are using it together. I will setup up DSD and record
2-3 hours of 155.97 and see if I can tell whats going on. Seems like Coffee county at
one time was going to be dispatched by Enterprise, I guess small towns are trying to save
money. As for New Brockton I've never heard them, but I'll stick what freqs I can find and
see if there is any activity. BTW I grew up in New Brockton.
Mil
millam
#15
Just plugged in 155.97 into SDR# and DSD. Here is what I saw.
2018/06/28 15:13:13 Current network: L337
2018/06/28 15:13:13 Current site: L337-9
2018/06/28 15:13:27 Group call; RID=6211
2018/06/28 15:13:35 Group call; RID=6211 [1911]
2018/06/28 15:13:39 Group call; RID=6342 [Elba Dispatc...]
2018/06/28 15:13:42 Group call; RID=6211 [1911] 6s
2018/06/28 15:13:51 Group call; RID=6342 [Elba Dispatc...]
2018/06/28 15:16:07 Group call; RID=6342 [Elba Dispatch] 1s
2018/06/28 15:16:11 Enc Group call; RID=6211 [1911] Alg=Sc 3s
2018/06/28 15:16:16 Enc Group call; RID=6342 [Elba Dispatch] Alg=Sc
2018/06/28 15:16:36 Enc Group call; RID=6328 [SF 181] Alg=Sc 2s
2018/06/28 15:16:50 Group call; RID=6342 [El@] 2s
2018/06/28 15:16:52 Enc Group call; RID=6328 [SF 181] Alg=Sc 4s
2018/06/28 15:16:58 Group call; RID=6342 [Elba Dispatch] 2s
2018/06/28 15:17:00 Group call; RID=6328 [SF 181]
2018/06/28 15:17:03 Enc Group call; RID=6342 [Elba Dis...] Alg=Sc
2018/06/28 15:17:45 Group call; RID=6328 [SF 181] 1s
2018/06/28 15:17:48 Group call; RID=6342 [Elba Dis...]
2018/06/28 15:18:55 Enc Group call; RID=6329 [---] Alg=Sc 2s
2018/06/28 15:19:00 Enc Group call; RID=6342 [Elba Dispatc...] Alg=Sc
Seems like Elba is dispatching for the county! Half is ENCRYPTED huh! Also it seems to be simplex.
Can a network L337 site 9 with Enterprise on LCN 91-95 have Elba transmitting on
LCN 1.
millam
#16
Elba [Elba PD DISP] is on S&P network L337 site 8 apparently. Coffee county
sheriff [Elba Dispatch...] is on 155.97 simplex S&P network L337 site 9.
Looks like I have not found 83 & 84 yet. joe jo can u help me with these?
This is what was on 151.775 during the night.
2018/06/29 05:25:40 Registration; RID=6029 TG=4000 ACCEPTED
2018/06/29 05:26:43 Group call; TG=4000 RID=6040 [Elba PD Disp] Ch=82 3s
2018/06/29 05:26:48 Deaffiliation; RID=6026 ACCEPTED
2018/06/29 05:26:48 Group call; TG=4000 RID=6008 Ch=83 2s
2018/06/29 05:26:54 Group call; TG=4000 RID=6040 [Elba PD Disp] Ch=84 2s
2018/06/29 05:29:08 Registration; RID=1703 TG=651 ACCEPTED
2018/06/29 05:30:31 Group call; TG=4000 RID=6008 Ch=82 2s
2018/06/29 05:30:35 Group call; TG=4000 RID=6040 [Elba PD Disp] Ch=83 2s
2018/06/29 05:30:38 Group call; TG=4000 RID=6008 Ch=84 2s
2018/06/29 05:30:42 Group call; TG=4000 RID=6040 [Elba PD Disp] Ch=82 2s
2018/06/29 05:31:27 Registration; RID=6026 TG=4000 ACCEPTED
2018/06/29 05:31:56 Group call; TG=4000 RID=6026 Ch=83 1s
2018/06/29 05:32:00 Group call; TG=4000 RID=6040 [Elba PD Disp] Ch=84 2s
2018/06/29 05:32:03 Group call; TG=4000 RID=6026 Ch=82 9s
2018/06/29 05:32:14 Group call; TG=4000 RID=6040 [Elba PD Disp] Ch=83 1s
2018/06/29 05:32:17 Deaffiliation; RID=6026 ACCEPTED
2018/06/29 05:32:34 Group call; TG=4000 RID=6008 Ch=84 1s
2018/06/29 05:32:45 Group call; TG=4000 RID=6040 [Elba PD Disp] Ch=82 3s
2018/06/29 05:32:49 Group call; TG=4000 RID=6008 Ch=83
2018/06/29 05:33:26 Registration; RID=6029 TG=4000 ACCEPTED
2018/06/29 05:34:51 Group call; TG=2401 RID=11090 [Car 170] Ch=84 1s
2018/06/29 05:34:57 Group call; TG=2401 RID=11219 [PD Dispatch] Ch=82 3s
Russell Co. Ala.
#17
By the FCC License the only output freq not in your list are 152.2700 , 152.3600 , 153.3650 and 153.7100. The input freqs. that are not in your list are 157.5300 , 157.6200, 158.2500 , 158.4375 , 159.5250, 159.6450, 159.7650, 159.7800, 159.8250. I would try the output freqs. first.
I will put them in my scanner and see what I find.
Russell Co. Ala.
#18
I have ran LCN finder for the past 2 night and got the same thing each night. Last night ran it for 4 hours 3 diff times so I am going to say this is right. The Ran is 8.
151.7750= 81 , 153.0125= 82 , 152.3600=83 , 153.3650=84. Software logged TG 2401 on 3 of the 4 freqs.
Russell Co. Ala.
#19
Mil have you confirm that 152.36 is 83 and 153.365 is 84. Also have you IDed any of the talk groups. Up tell 10 years ago I had a aunt and uncle that lived in New Brockton for 30 some years. GOOO GAMECOCKS
millam
#20
LCN's are good. As far as talk groups I don't listen that much, all I can do is list what
DSD has listed for that network. Gamecocks were state champs in 64 when I moved to
Enterprise. I was too short and fat to play basket ball and to slow to play base ball. Nerd,
played with radios and tv's.
Mil
