ericsson 700p software
rcla39652
conroe, Texas
Does anyone know what programming softeware I would use to programming software I need to use or download to program my ericsson or cougar 700p radio.
thanks
Royce Claborn
KevinC
32D2T/957.282
Super Moderator
I'm everywhere Focker!
I’ll just add that I moved this from the “All other scanner manufacturers” forum. So the OP may not know what they really have.
K2NEC
5F6
I got the idea when I read "cougar 700p" (It's a Jaguar 700p)
Same animal category, just not close enough :)
rcla39652
conroe, Texas
I am not sure what you are trying to say. Are you saying that the list of programs you have listed will work for my radio or what?
Royce
BMDaug
I am licensed…
Central Colorado, USA
Royce
“Programmer” software is the older version of what is now the RPM (radio personality manager) line of programming software. The latest version of RPM1 is V14, but there were many versions of RPM prior to 14. Now, Harris has released RPM2, which is a total rework of RPM1. RPM2 will not work for you, but RPM1 or the older Programmer software will get this radio programmed.
Programmer is no longer offered for purchase, but RPM1 (V14) is bundled with RPM2 when purchased from Harris. The least expensive RPM2/RPM1 bundle is available ok CD from L3Harris for around $850, or can be downloaded from the L3H Priority TechLink Portal, provided you have an account which costs around $3k/yr.
I have the CD and a single computer license… My dealer was generous enough to transfer the contents of the CD to a dealer supplied flash drive free of charge for installation without a CD drive… I then called L3H TAC to get the license set up on my machine.
-B
merlin
DN32su
If you can get it, I recommend RPM v 14c05. It will program all firmware versions of the Jaguar series radios.
TDR-94
RPM only supports the RU model of the 700P. The KRD model of the 700P is only supported in ProGrammer. The RU models can be programmed with both ProGrammer and RPM, depending on which software it was last programmed with and the firmware version.
rcla39652
conroe, Texas
Ok thanks for your information. I purchased the software program from Harris site. I don't know if I download the right one. I will let you know when I install it next week.
Royce
TDR-94
L3HARRIS TAC doesn't provide downloads of it's programming software (it's sold in a disc psckage) and they don't sell directly to individuals. ProGrammer can not be purchased. It's long been discontinued and RPM2 comes packaged with RPM1 vR14C05. You can only purchase the packaged bundle. RPM1 vR14C05 is not sold individually.
ElroyJetson
Those are pretty old radios. What are you intending to listen to with it? Is it even the right band for you?
(VHF, UHF, or 800 MHz)
The 700P doesn't support any version of P25 communications, not trunking or conventional.
Very few EDACS systems are still operational. (I'm only certain of ONE...)
They're very heavy radios, due to the use of a lead-containing alloy in their cast frame.
It's worth it to find out now if the radio can even do what you want.
CanesFan95
Was Homeboys-Scanna
Banned
FL
I think there's more than 1 EDACS system still operational in the world today.
rcla39652
conroe, Texas
I have a Jaguar 700p system (KRD 103161) I am using the ProGrammer software to connect to my radio. My problem is this software want import the format form RadioReference. I live in Texas in Montgomery County. I need a file with information from Montgomery County that in the format for ProGrammer software so I can import it into my radio. If someone can help me I would be most grateful. If there is any other information you might need please let me know.
thx
Royce
KevinC
32D2T/957.282
Super Moderator
thx
Royce
You’d have better luck with a scanner. And MCSO and Conroe PD are encrypted so you can’t monitor with a real radio or a scanner just so you know.
BMDaug
I am licensed…
thx
Royce
That’s a pretty niche request… I’d start learning how to enter it manually. Programmer is old and not commonly used anymore.
Good luck,
B
rcla39652
conroe, Texas
I would like all of Montgomery County, TX like Sheriff, police pd, ems, and fire departments things like that.
thanks
Royce
