Error Code 304
WB6WQF
Sacramento, California
What are you trying to do?
You dont have no feed under "JPOPatents"
That's correct - the feed is W0WEB and this is the message:
Auto Config Error code # 304 - There are no feeds associated with the username "w0web"
Look at the "Live Audio" page and you will no longer see the feed - but it should be there - George has been trying to reestablish the SF Fire feed, but is apparently locked out.
kendrik578
Live Audio Administrator
Greensboro, NC
I believe Lindsay has stated to you many times he terminated his feed because he didnt wont to follow our rules. That means he no longer has a feed on RR and can not broadcast, you cant log in to scannercast if you no longer have a feed.
kendrik578
Greensboro, NC
Also a new provider is now broadcasting SF Fire.
He should have thought about this before he decided to throw a hissy fit and discontinue it.
WB6WQF
Well that's an unfortunate turn of events, I must say. When I contacted Lindsay and asked if W0WEB's feed had been blocked, I was told that it had not been blocked but W0WEB had terminated the feed. As a result, I told W0WEB that RR was not blocking his feed and asked him to reestablish the feed for the benefit of everyone. But, I guess it is blocked.
I don't ordinarily get into the politics, but, since I'm a lawyer, I will advocate when there appears to be a misunderstanding or injustice.
Thanks for the insight into this situation.
kendrik578
Greensboro, NC
When a feed is terminated it means its gone for good, or in other words, its deleted from RR. He was the one that no longer wished to broadcast anymore, therefor it was deleted.
WB6WQF
Kendrik,
I just got off the phone with George and, listening to his side of the story, I would not agree with your statement that George was the one who no longer wished to broadcast. It would appear that there has been a big misunderstanding. Therefore, please refrain from posting that George terminated his feed. Also, since RR has a replacement feed and is not going to allow George to host the feed, there doesn't appear to be a need for further discussion. Thanks for taking the time to kick this around with me.
kendrik578
Greensboro, NC
Kendrik,
If George wants to discuss this then George can talk to us directly and not through a 3rd party. Il be happy to discuss it with him.
