ERROR CODE G5
bbo14
Hobbs, NM
I turned on my G5 this morning and got an error message about software. Advised me to push three buttons, "RESET + DVR + PLAY for three seconds to manually reset and then contact Unication Tech Support and advise of ERROR CODE #ffff2".
What key is "DVR"? I know where the other two keys are located.
Unication's support tab says to contact the dealer. Dealer has not seen this. This unit is out of warranty.
Is there a way to ask Unication directly what is wrong here and what can be done about it? Has anyone else had this come up?
S/W 1.31 in use here. Is this one of those, "take the battery out, turn the unit ON to clear the error" scenarios? Any help/ideas black magic appreciated. Thanks.
IAmSixNine
Dallas, TX
The 3 key method and taking the battery out are pretty much the same thing. I never got the hang of the 3 key method so i never used it. Anytime i had an issue battery pull is my go to.
If that dont fix it, then reloading the firmware.
hakwye8518
Town of Islip, NY
I cant remember which buttons exactly but its one of the side buttons (top side button I think) the little button on the channel knob and then one on the front of the unit. I had to do this alot when i first got my g5 it ended up getting rmad to unication. A battery pull and reset that way will also work, if this is a one off time you had to do this thats fine but if it keeps occuring you may need to send it into unication.
lebrunmn
Retired... Get off my lawn!
Hampshire County, WV
Could that be the Voice Memo Key--the smaller key just below the Reset Key on the side of the G5? I thought that I'd heard that button referred to as the "Digital Voice Record" button at one time, but haven't been able to find the reference.
bbo14
Hobbs, NM
Wow! Three great answers! I did "fix" it by removing the battery and letting it go "stupid". (I have had to do this to a lot of radios over the years, so it's no big deal to do). I agree, if it decides to "wig out" again, I'll contact Unication and send it in. (Wonder how much the fix will be?). Glad I didn't have to reload s/w. Not especially painful, just hoping it wouldn't come to that. Glad I got it operational. Weekend coming up. Covering the inevitable: sick calls, bar fights, batteries, car crashes. Gotta say, this is one heck of a scanner, for something never designed to be. Audio will wake the dead! I have our county-wide 800 trunked system and some conventional VHF in it. amazing device. Gonna load the statewide 700 State Police system and listen while I can. You know what I mean. Thanks to all three of you for the suggestions and "witchcraft" re: the three buttons. 73, and happy listening this weekend.
hakwye8518
Town of Islip, NY
You can also try disabling over the air messaging and a couple other options. I dont have the cps in front of me to see which tab its under.
bbo14
Hobbs, NM
I don't have messanging enabled. Anyway, so far, it's not had a relapse. Hope it's in remission. Thanks.
