Error message and lock up of PSR 500
Bentley Alberta Canada
#1
I get a error response on a PSR500 that reads Heap error 22CD21 : 22D4 and then scanner locks up
How do fix that error
It will come up in the scan mode when i press any of the number keys
Anne Arundel County, MD
#3
You have a talkgroup not associated with a system.
The heap error description at the above link should explain.
You need to delete a stray record that is not associated with a system, or change it so that it is.
WS1095/536/436/996P2/HP1e/HP2e/996XT/325P2/396XT/PRO668/PSR800/PRO652
