error Messages on DSDPlus
Hauppauge NY
#1
Hi, folks. DSDPlus via my WS 1080 discriminator output works great on my ten year old Aspire laptop with the "Line In" in addition to the microphone port. Bought a new Lenovo. No "Line In", just the microphone port, and it would not take any audio from my WS 1080. Checked around and found out that I needed an external sound card. Bought one; it has separate inputs for Line In and microphone. Nothing via the Line In but the microphone port accepts the audio signal into the laptop and the signal gets processed, but I consistently get error codes. 1 - Is that why I'm not hearing anything ? 2 - Does this have to do with an incorrect configuration of the com port into which I have the sound card connected ? 3 - Any other ideas? Much appreciated, folks.
#2
Initial thought is check the levels, Microphone boost, kbps rate, mono/stereo. If the computer has a built in microphone mute or disable it as room sounds creeping into the audio will mess you up. Also check any "smartaudio" filtering/mixing etc. that might be running.
#3
I'd say the error codes are most likely to be as a result of feeding the signal in via the microphone socket......it's pretty much guaranteed this will give you problems. I doubt it's a COM port error, though you possibly have an issue with the driver for your soundcard if the line-in isn't working?
Try to focus on getting the line-in feed working (check driver/volume control/set to maximum quality decode levels/check that both Windows and DSD+ is selecting this input as the default recording and input device etc). Failing that i might try a new soundcard: I recommend this startech model:
https://www.startech.com/uk/Cards-Adapters/Sound/USB-Audio/External-USB-Sound-Card~ICUSBAUDIOMH
#5
I have the same setup minus the ws 1080 and had to use a special adaptor to plug into my mic input, the adaptr has the mic in and headphone in which you plug into the mike input. That is on a lenovo t420.
Beaverton, OR
#6
I was unable to get detectable audio into the microphone input of some USB audio dongles until I realized that the microphone inputs were three-conductors. The tip is the audio input, and the ring is a bias voltage for the microphone. I had to make adapter pigtails which left the ring connection of the microphone jack non-connected, the audio from my scanner to the tip contact, and the shell of the microphone jack to the shell of my scanner audio cable.
I found that inserting a two-conductor plug into a computer microphone jack gave mixed results. Sometimes it worked, sometimes it didn't. Using one of these pigtails with the ring/mike bias contact disconnected always worked for the inputs I tried. It took waaaay too long for me to figure this out :-(
Toronto, Ontario
#7
The signal from the scanner is likely designed to feed a line input, which would make it too strong for a mic input.
That would be my guess.
The sound card connects to a COM port? Never heard of that before.
If you record the raw audio of a strong local signal and upload that audio somewhere, we could give you definitive answers.
