ERS-OCI DSDPlus Data files
n8yid
Preble County, Ohio
Has anyone ever came across a system Map for this System? Some providers "push" out a .TXT file/map for their system that has each sites run-down (ie. location of sites, frequencies in LCN order, Control Channel, etc)...
I have been anxiously waiting to get one for this system, using the Richmond (Wayne County) & New Castle (Henry county) sites; when I'm in the Richmond area...
Doesn't tell "user" info; but, a ton of other important info that we could use around here...
Just wondering...
Dave T.
Reconrider
Inside the Galaxy
Radio Galaxy
You should submit this to the RR DB and they will add it to the database for that system instead of bumping this thread every few days
west-pac
It's already in the RRDB. I have no idea what this thread is for.
INDY72
Indianapolis, IN
If you happen to find any new conversions of the last few analog 800 MHz sites, that would help out the DB greatly. They were supposed to be converting them over to Capacity Max, or Capacity Plus if I recall, and were adding a new 800 site to the downtown site on America One but that got delayed by COVID etc... They are going to eventually run an 2 or 3 level set up for the larger use areas, with Cap +, and Cap Max sites added to the Con+ sites. So far they have 2 dual layer areas Indy and the one down around Louisville. Both with Con+ and Cap+ sites.
mtindor
FMP24 PRO USER
Carroll Co OH / EN90LN
Still nothing on their 800 mhz Indy license a year later? I'm assuming this is the one you are referring to since it's at One American Square and had a construction notification filed back in 10/2020 (during COVID). Just wondering if you have checked on this recently.
WRFB802 - DMR emissions
854.5375
854.6125
854.6875
854.7375
