Just because a test is performed in the CAP doesn't mean that the manufacturer of the radio can't allow the programmer or system administrator to enable or disable the feature.
Actually this has everything to do with the CAP process.
Under current TIA-102.AABD-A Section 6.4 Full registraion it states:
A SU shall perform full registration when:
a. it is switched on; or
b. it automatically or manually selects a new Registration Area in the same or different WACN; or
c. it is forced to register by the RFSS.
The SU may be forced to register by the FNE when an optional registration time out occurs or in the case of the FNE losing track of SUID to WUID mapping. An SU that fails to respond properly to a forced registration should be considered as no longer registered and the WUID no longer valid. d. it is a roaming SU which is leaving an isolated site for another site.
Since this is a mandatory section of the standard, it must be followed and the manufacture does not have the option of disabling it. If what you say is true about the Harris products and they do in fact work as described, I would be willing to bet you will either see that feature removed in the next year or you will no longer see any Harris products with CAP certification. My guess is that feature will be goon soon
