Dorpmuller said:
Just got my E1 yesterday. Really low s/n. (1867)
Only issue I found so far is that with the AC adapter I pick up a hum on some stations and sensitivity is good... but when I pull the adapter and go to batteries the sens goes all to hell. (using the int. whip)
Anyone know if this is indicative of a problem?
Hmmmmmm... I initially tried mine, SN: 07664, with the supplied `WallWart' adapter, just to make certain that it would work basically, and then carefully packed it away. (Since I use 9VDC adapters for my PRO-96/97s I already have more than enough 9VDC `WallWarts' already plugged in around the house in `strategic' locations and I figured I'd just use one of those instead.) Anyway... I've tried running mine off of both the RS# 273-1771 and 273-1772 adapters and haven't gotten either the hum problem nor the sensitively problem you seem to be having. Now... As ka3jjz has mentioned there is/`was?' a different adapter that was supplied with some of the first units. From what *I* can tell the earlier ones looked sort of like a small `brick' that had a detachtable 2-prong AC cord for the AC and a fixed cord for the DC out. The one *I* got with mine is a `standard M1?' `WallWart' with a 3-prong plug for the AC and a fixed cord for the DC out. I suspect that the `WallWart' type with the 3-prong plug is probably the better of the two because of it's most likely having grounding and a bit of shielding. (The really strange thing is that *both* of the RS adapters are `switching' *and* only have a 2-prong plug and *both* of them a *very* quiet with both my scanners and the E1. [In fact I was actually able to operate a PRO-96, a PRO-97, *and* my E1 at the same time off of either RS adapter without any problems! The only problem I can easily foresee is that it appears that RS has discontinued the smaller, the 273-1772, of the two adapters. Though... {GRIN!} It actually might not be all that much of a problem as the 273-1772 was supposedly only capable of 9VDC @ 1300ma VS the 273-1771 which supposedly is capable of 9VDC @ 1500ma. BTW, the 273-1771 is also supposedly an `international?' unit and besides being able to operate off of 100 - 240VAC 50 - 60HZ has a fold up 2-prong AC connector which would make it a lot easier to pack along with the radio when traveling. Just make certain that you've got the right `adapt-a-plugs' for your 9VDC radios, a couple `adapt-a-plug' "Y" adapters, and maybe 1 or 2 `adapt-a-plug' extension cables with you and you'll be able to listen to just about anything you may want to listen to. {VB GRIN!}])
Back to the `WallWart' VS the `brick' style original adapter... Your `apparent?' loss of sensitivity *could* be because of the DC cord of the `brick' style adapter was acting like a `counterpoise' for the radio/antenna? *If* that was the case you could fairly easily test to find out by possibly taking a proper `adapt-a-plug' and the `adapt-a-plug' extension cable and then setting the radio to switch to batteries upon AC power loss and plugging in the plug and extension cable setup to the power jack. If it is acting like a `counterpoise' you should be able to notice it. (You *may* also want to also try hooking the negative side of the cable assembly to a known good ground, too? [I don't think that trying to hook the positive side would be all that `great?' of an idea. {WAN GRIN!} Even though it probably wouldn't do anything *I* wouldn't want to take any chances no matter how `lucky' I might be feeling at the time. {CHORTLE!} $500 is *way* to much of a `bet' to me! {GRIMMACE!}]) *If* it does act as a `counterpoise' I think that *I* would be inclined to have a bit of a talk with the place I bought the radio from and see if they would either replace it with one that has a serial number above the range of serial numbers that Universal Radio is selling or refund my money so that I could get one from Universal radio. (I *do* know that the one *I* got from Universal Radio both doesn't have the hum nor the sensitivity problems. Plus, even though you may think that getting the G4000A might be somewhat `useless' or `redundant' it just may turn out to actually be good in the long run as a `beater' radio at the very least.)
Just an `Olde Fart's' 2¢ worth.
