Question about the antenna on the Eton, is the antenna input jack for HiZ or 50ohm input?
Interesting. Antenna construction articles almost always advise getting an antenna up as high as possible, but I'm not surprised at all that this works well.Exactly that. A continuous loop of wire laid on the ground. For speaker wire, simply split the far end of the wire, connecting the two ends. Spread it out as evenly as possible, and connect the close end to a wire terminal x mono 3.5mm plug. They can be tuned to a specific band for weak signal work, but for general listening, more wire is better.
Back in the late 80's, my uncle gave me an ancient Hallicrafters S-40A as a Confirmation gift, along with a small roll of insulated hook-up wire. I just ran the wire around the floor in my room and was listening to the world.
