k9rzz
I picked up three of these on eBay for $10, none operational, but I figured that out of three that I could get ONE working.
I've got one running on AAA batteries and it's pretty nice. I'm listening to WYFR on shortwave and earlier had China Radio Internaional. I can hear WWV for the current time, and it seems to work well on AM and FM as well.
Taking one apart is a challenge. Remove the screws in the back and then carefully pry the side covers off next, then the the two main halves starting at the hand crank. The halves are glued together! Granted, there is a water proofing gasket in there too, but just be careful when you do it.
On two of mine, the hand crank has no resistance - for good reason, two of the teeth on one of the plastic gears are broken! The gears are heavily lubricated to help prevent that, but it they still sheered off.
I will try to fix that and post results (with pix).
