Ettus USRP X300 - How send 2 signals TX synchronized
Fifi44000
With an USRP X300 and 2 daugthers boards LFTX (one fixed on A and the second on B), I need 2 outputs signals synchronized.
I programme in C++ language on Linux, UHD version 4.8.0.0
Result:
With an oscilloscope, the 2 outputs signals are monitored:
- Channel 0 => Ok, I see a sinusoidal signal, so it's seem ok
- Channel 1 => Ko, there is no sinusoidal signal, but I don't understand why !
Please, help me to resolve this problem ?
// USRP creation
std::map<std::string,std::string> device{{"addr0","192.168.10.4}, {"master_clock_rate","184.32e6"}, {"clock_source","internal"}};
uhd::device_addr_t arg_device(device);
usrp = uhd::usrp::multi_usrp::make(arg_device);
// Front End of daughterboards
std::string subdev("A:0 B:0");
usrp->set_tx_subdev_spec(subdev);
// Configuration of channels
usrp->set_tx_rate(rate, 0);
usrp->set_tx_rate(rate, 1);
uhd::tune_request_t tune_request(freq);
usrp->set_tx_freq(tune_request, 0);
usrp->set_tx_freq(tune_request, 1);
usrp->set_tx_gain(1);
usrp->set_tx_bandwith(bw, 0);
usrp->set_tx_bandwith(bw, 1);
usrp->set_tx_antenna("A", 0);
usrp->set_tx_antenna("A", 1);
// Init
usrp->set_time_source("internal");
usrp->set_time_now(uhd::time_spec_t(0.0));
// Get streamer
uhd::stream_args_t args("fc32", "sc16");
args.channel = {0, 1};
tx_stream = usrp->get_tx_stream(args);
// Init PPS
usrp->set_time_unknown_pps(uhd::time_spec_t(0.0));
// Metadata
md.start_of_burst = true;
md.end_of_burst = false;
md.has_time_spec = true;
md.time_spec = usrp->get_time_now() + uhd::time_spec_t(0.3));
// Data
std::vector<std::complex<float>> buff0(nbEch);
std::vector<std::complex<float>> buff1(nbEch);
std::vector<std::complex<float>*> buffs;
buffs.push_back(&buff0.front());
buffs.push_back(&buff1.front());
// Data
for (size_t n=0; n < nbEch; n++)
buff0[n] = cos(2 * M_PI * 28000 * n);
buff1[n] = 3 * cos((2 * M_PI * 28000 * n) + M_PI / 2);
// Send
num_samps_sent = tx_stream->send(buffs, nbEch, md);
