Every 2 to 4 sec noise like keying mike.
ctester
New Johnsonville, Tn
The trunk system i listen to is LCR Passport. The voice is Analog. Every 2 to 4 sec there is noise on my scanner like someone keying mike. I think this is called Data Bursts. Is there anyway to stop this or filter it? Or will i need a new scanner? Thanks
lowerrollin
Anderson County, TN
sounds like your trying to listen to a LTR passport system on a conventional scanner. To my knowledge, a scanner isn't available to decode the data in passport systems, just regular LTR. That noise is indeed data from the repeaters, "talking" to the handhelds. I would turn off delay for all channels and keep it as is.
fineshot1
NJ USA (Republic of NJ)
What your hearing is normal for a passport system.
Each repeater keys up every two or three seconds and transmits a short burst of data to the mobiles
on the system.
There are no scanners that come from the scanner manufactures today that can trunk track a
passport trunk system so your stuck with listening to the system in a conventional fashion.
South Central Minnesota
Are you sure its a PassPort system, not just a Standard LTR...Standard also does the idle burst transmission...I don't hear them when scanning the system, only if I choose to monitor of of the freqs on the system.
fineshot1
Standard LTR systems do not idle burst every 2 to 4 seconds.
The interval on a Standard LTR system is longer - in the range of about 10 or 11 seconds.
Jay2052
West Chester,PA
i have the same problem in Chester County PA, with the LTR Multi-net. It is annoying, But I live with it, As far as I know there's nothing you can do about it.
