EVX534 Problem
Annocht
Good evening,
I’m a relative newbie to the radio game and purchased some Vertex EVX534’s for a good deal to learn the ropes with and potentially do some simple fixes. A common problem between the radios I purchased is that the volume knobs either a) won’t turn far enough counter clockwise to turn the radio off, hitting a hard stop right before they turn off; or b) the volume knobs will be able to turn 360 degrees (which they’re not supposed to, there’s a limit on how much most of them can spin with the counterclockwise stopped position being “off” and the clockwise stopped position being “max volume”) and the radio won’t turn off in any position of its 360 degree travel arc. I was wondering if someone could point me in the right direction as to what I should look at/parts to order before I start taking them apart? I tried replacing the exterior knobs and that didn’t fix the issue, not that I expected it to. Thanks in advance!
-Connor
