Explain the PSR500 Expert Settings please
thewenk
Idaho DB Admin
Eastern Idaho
stlouisx50 said:
Thanks for all the great info. Could you tell me what Max tunes before complete RF HW update means under the MAX TUNES setting. I do not understand.
Sorry, I don't know what Max Tunes is either. Maybe someone else can elaborate.
Dave
fmon
Silent Key Jan. 14, 2012
Eclipse, Virginia
This may be of little help also.
Access via PGM>FUNC>GLOB.
FUNC>SEL provides info.
WIN500 = Max cached tunes under General Tuning in Extended Settings tab.
PSREdit = Max Search Tunes per Scan Cycle under Sweeper/Search Options in Weather/Advanced Configuration tab.
ARC500 = Max Tunes under Global Settings Expert tab
Anyway, the setting value appears to set the number of tunes prior to restart of new group.
