Extending my coverage on PSR-800 with 800MHZ antenna
Bronson24
Frostproof,FL
Is there a setting to extend my coverage with my PSR-800 with a 800Mhz Antenna? I seen something about ENC Lever its at -24DB right now....then ADC gain its at +0db right now and the DAC is at +0DB right now... DSP level Adapter? IF out is off....Flexstep?? M36 Stat Bits??
Halfpint
Slightly NE of the People's Republic of Firestone
You don't need to futz around with any of those settings for now. *Maybe* they *might* come in handy at some future time. Just go ahead and use the antenna.
