External drag on performance
D
DaveNF2G
Guest
Lately it takes a long time for pages to load on RR. The cause seems to be something coming from ping.chartbeat.net that times out, preventing RR pages from loading.
D
DaveNF2G
Guest
It seems to be much better this morning.
[EDIT] I spoke too soon. Could not get in to the very next forum I clicked on. Connection indicator spinning, status reads, "Transferring data from ping.chartbeat.net..." Waited several minutes then aborted.
WayneH
Forums Veteran
Super Moderator
Your master site
I'm not sure why it's a problem for you but if you're using FF you can install an extension called Ghostery to block Chartbeat (or any other tracker/analytic).
poltergeisty
Truth is a force of nature
Banned
RLG, Fly heading 053, intercept 315 DVV
MtnBiker2005
San Diego County, California
Info from this page..
http://blog.ryanrampersad.com/2009/07/22/what-is-ping-chart-beat-net/
http://techcrunch.com/2009/12/14/chartbeat-typepad-dreamhost/
1.) you can easily block it with AdBlock Plus and adding ping.chartbeat.net as a custom filter, in Firefox.
2.) The easiest way to block it is to add a line to your hosts file to route ping.chartbeat.net to your local machine.
The hosts file is located in /etc/hosts on OSX and *NIX, and in c:\windows\system32\drivers\hosts on Windows systems.
Simply add the line
127.0.0.1 ping.chartbeat.net
And now whenever any program on your computer tries to access ping.chartbeat.net, it will simply be redirected to your local machine, resulting in a “page not found” error.
VigLink option you can optout.
If you'd like to disable VigLink on sites that you visit.
http://www.viglink.com/support/optout
Quantcast Opt-Out
http://www.quantcast.com/how-we-do-it/consumer-choice/opt-out
Ghostery
http://www.ghostery.com/
