Hi, has anyone experimented with external speakers and the SDS200?
I got two and neither one hums that I can hear.The speaker on the dds200 really good, I’d imagine it be even better without the darn hum noise coming out of it
Sent from my iPhone using Tapatalk Pro
Sent from my SM-N960U using Tapatalk
Maybe my hearing is going...along with everything else.I’m glad to hear that, I tried 2, and they both sure did
Did you see the official Uniden-approved DIY fix and part that is coming soon? Apparently that is the permanent solution per Uniden.The hum is an easy fix. Just take the outer case off ,remove the screws from the inner metal case top. Push that inner case top as far forward and down as possible,hold in place, put screws on inner top back in. Put outer case back on. Hum should be gone. Or almost gone.
The Uniden BC23A has a volume control on it -it also requires power - I am using one of these for my SDS200 / 2 BCD536HPs / HP-II. A bonus is the redlight on activity.
No you will need a power supply since it a amplified speaker.I’m gonna be using this in my house, so I don’t have to have a power plug do I? Just plug into scanner?
You would need something like this.Not sure what I’d need, can you provide a link to amazon to what I’d need for it, thanks.
Sent from my iPad using Tapatalk Pro
