Extio plug0in for SDRplay?
D
DaveNF2G
Guest
The .dll normally goes into the same directory as the software that needs to call it.
More complex software that actually uses the Windows environment data can access libraries from wherever Windows wants them to be.
NYG
when installing the extio using the utility, drill down into the directory that HDSDR is installed in and select the HDSDR executable. then just continue the install.
SDR console i believe uses it's on dll and doesn't rely on extio.
