To pick up SSTV signals on the F.M. bands, such as the recent International Space Shuttle broadcast at 145.8000, should my scanner be set to NFM or WFM?
SSTV is just audio tones, in this case sent over normal FM ham radio. I don't know exactly what equipment they have on the space station but it most certainly is not WFM, that's only good for the 88-108 MHz broadcast band. If you are listening on a scanner set it to FM first and if the audio is too low use NFM.
Wide FM is what amateur radio uses. 5 kz deviation. Narrow is what part 90 business band uses now. 2.5 kHz deviation. Broadcast is not factored in this equation.
This applies to a radio transceiver.
What you say applies to a scanner or rtlsdr device.
