F3061D Scan
rr6404
Chambersburg, PA
Is there any way to get the "scan" options to appear in the software with the 3061 that has the digital option installed? I read in another thread that the scan option disappears when the digital board is added. I have analog channels programmed but still see no "scan" in the software. Thanks for any help.
Bill1957
New Jersey
Hi,
Yes,the scan option does dissapear when you program it for digital. It's the one fault of an otherwise nice radio. I keep two templates for the radio_One is for analog with scan and the other for digital.
rr6404
Chambersburg, PA
Thank you for the response. Please forgive my ignorance but what do I need to do to change the profile to analog? When I started, LMR (Digital) was pre-selected. Do I select one of the other options such as LMR (LTR) or LMR (2Tone) and then write to the radio again?
Bill1957
New Jersey
f3061
Just change to LMR 2-Tone,then program your non-digital frequencies.Save them as a .icf file and you can just switch them whenever you like. I have a seperate digital.icf and one for analog.
